Soundman,
Yes, you can play your CDs on any player, as long as you use a CD writing programme such as Adaptec Easy CD Creator, Ahead's Nero, Feurio or whatever. Your .wav files will then automatically be converted to CD-audio files (.cda). You can also write .wav files to a CD, but then you are actually producing a data CD, and not an audio CD. The .wav files will not be converted and the CD will not play on a normal CD player. You can play the .wav files on your computer, though. The same goes basically for .mp3 files.
Now back to your question. You should always record to .wav files because this is the standard format for computer audio files. Step by step:
1)connect your tape recorder to the line in of your soundcard.
2)start your soundcard's mixer programme and select the correct recording source. If possible, mute the mic, modem, tv and other recording sources in the mixer programme. Now play a loud part of your tape and set the recording levels so that they touch on the red. This needs some experimenting but it is very important to get your input levels right. If they are too low, you get more noise than necessary and if they are too high the sound may be distorted ("clipping").
3)Wind back your tape and start cdwav.exe. Hit the playback button on your tape deck and the red button of cdwav. If you want, CDwav will now record one side of your tape as one huge .wav file. I recommend this if you have approx. 500MB harddisk space left.
4) When the recording is finished, use CDwav to split the huge .wav file into single tracks. You can also cut out silences or other unwanted passages. These are treated as tracks but can be left out of the playlist. Put all the tracks that you want on your CD in a CDwav playlist and save the tracks. CDwav will now produce single tracks. After this, you can delete the original huge .wav file
5) Using a CD writing programme, in "audio CD mode" put the tracks in the write order and write them to a CD. They will be automatically converted to the CD audio format.
Rubicon
