When i try to convert tracks 7/8 to a stereo wav file i get a message saying "out of capacity".I deletedthe song and reformatted the card itz 256mb.i redid the song itz 4m10s long and only 4 tracks. The very 1st time i used this function it worked fine and now it doesn't.
Let's start over again..Follow these instructions please..
Please refer to the page 68 of the manual
1. Make sure you are in the Song where you recorded the individual tracks.
2. Press 1-4>5/6, 1-6>7/8 button TWICE so that 7/8 button and RECORD buttons blinks in red.
3. The 1-4>5/6, 1-6>7/8 button should be solid red as well.
4. Display should say BOUNCE 1-6->7/8. You are now Track bounce 1-6 to 7/8 rehearsal mode.
5. For the best result bring up the MASTER FADER all the way up.
6. Adjust 7/8 fader to the shaded are, the 7/8 fader does not affect bounce level, this is just monitor level.
7. Adjust Channel Faders, for the best channel balance, yet highest possible positions.
8. Adjust PAN, EFFECT SEND knobs.
9. If you like enable one of the MASTERING EFFECT (POWERFUL, NATURAL and BRIGHT).
10. Press Play and listen to the bounce rehearsal.
11. If the monitored audio is clipping, back down the MASTER fader slightly. If it is not clipping leave the MASTER FADER at Max position.
12. Practice you mix as many time as you want.
13. If you are ready, make sure you are at the beginning of the song and press RECORD and PLAY BUTTONs at the same time so that the RECORD button and track 7/8 buttons changes to solid red.
14. Press STOP buttons to stop the track bouncing.
15. You should see ?Post Recording! Please Wait.? In the display.
16. Display should change PLAY 7/8, and track 7/8 buttons still blinking in red.
17. You can check the result of the track bouncing now.
18. Now, bring up 7/8 and MASTER FADERs to the shaded are. Other channel faders (1-6) do not matter.
19. Rewind back to the beginning of the song and press PLAY to hear the result of the track bouncing.
20. If you do not like the result, repeat the 1-16 above.
21. Now you are ready to perform stereo wave file conversion from this track bouncing.
Please let me know if this works or not
