Can't make a mix cd with easy cd creator
  • Thread starter Thread starter jaynefair
J
jaynefair
I hope i'm in the right place!! Ineed help!! Is it possible to mix a cd with the easy cd creator? Are there any tricks to do this? I'm dying to get some of my favorite songs on to one cd!! I hope someone has an answer. Thanks!!!!!!
Sure, you can make a compilation disc with it. Bypass that wizard screen that it normally starts up with (hit cancel), then select the audio tab at the top and start picking tracks. I normally pre-record the tracks to wav files to keep from having to switch discs. Just put the CD in the drive that you want to copy songs from, select the CD drive and the songs in the Easy CD explorer window, and drag them to the bottom part of the screen where the new disc layout is. When you get all the songs from a disc that you want, select them all, right click and pick pre-record to wav file. It will asks for what you want to name each track, then copy them all the the hard drive. Then do the next disc and so on until you have what you want to burn.
