can't get rid of digital popping
  • Thread starter Thread starter toadies
T
toadies
My setup.
keyboard to digi001 via MIDI
pipeline (midi to lan) to Reason
Sound Blaster SPDIF out to digi001 IN
i tried messing with buffer like crazy, can't get it to stop.
I actually think i fixed it as i'm writing this, I went back to analog 1/8" to 2 RCA plugs. No pops.
Why was it doing this in SPDIF? isn't that suppose to be digital
I had a popping problem going SPDIF thru external preamp/converter into the Digi001. What fixed it for me:
I went into the ProTools session setup window and set the sync mode from "Internal" to "RCA (SPDIF)." Buffer had nothing to do with it.
This may not be your problem -- since you have a complicated chain, the problem may be elsewhere. But try this first if you haven't yet ... I don't use Reason so I don't know what settings would apply to that. Good luck.
Your buffer isn't the problem. It's the S/PDIF. The S/PDIF source has to be the clock master and what ever recieves the incoming S/PDIF signal should be the clock slave.
