R
rmarchand98119
Here's a weird question: I've experienced this with both software recording packages I use (Cakewalk HomeStudio and SAW Studio 2.6).
When I am playing back the file that I'm mixing down, everything sounds fine and it's nice and loud. I then hit the appropriate "build to sound file" commands to build my WAV file.
Then, when I go either listen to it through Windows Media player or burn it to a CD, not only is it not near as loud is it was when playing back through either program, but it's way softer than any other professional CD/Soundfile that I have.
Why isn't the sound file's volume the same as loud as it is when I'm playing it back through the Cakewalk or SAW?
, I think you might be expecting a bit much from your abilities as an engineer right now to expect that you can actually get your material as loud as the big boys do. Let's just say that since you have to ask "why?", you give away the fact that you lack the essential experience to make it happen right now. The fact that you are using the "lesser" Cakewalk product tells me you don't have the gear necessary either to make this happen.
