Can't Get Audio In/Out
  • Thread starter Thread starter smithmusic
smithmusic
I am using Cubase 5 and have Windows 7. My soundcard is a Focusrite Saffire USB 6. I can't seem to get audio in or out of my computer. Everything is hooked up. Cubase recognizes my device. I have the driver and the device configurations set up properly I believe. Can anyone help me. I have searched relentlessly online. This use to work and I messed something up but I don't know what.
Inputs are active as you have shown and should be able to record like that.
You didn't post your outputs tab so no idea if you botched that or not.
Make sure you are either listening in headphones connected to the saffire or have speakers connected to the saffire.
Familiarize yourself with the mixer knob. One way will give you the audio as it comes in to the saffire, and the other way will give you the computer/cubase playback audio.
Also:
It's weird that out's 3 and 4 would be inactive to me because they are analog outputs. But unless you need them for some reason then the configuration should be ok.
