P
pennylink
I'm a guitarist primarily, but play a little bass so I can lay down bass lines in my humble home recordings.
Here's my problem: once recorded, some of my bass notes sound much "bassier" than others, and not just the lower notes. For example, an A note played on the E string will sound much bassier than a low E or F note on the same string! I've tried to adjust how hard I hit the string to compensate but it just doesn't seem to do the trick.
Another example: playing a D note on the E string will sound much bassier than playing the same D note on the A string... what's up with that?
When I look at the recorded wav file the notes appear roughly as loud, they just sound so inconsitent. Even when I put a compressor plug-in on it, it still doesn't compensate for the difference in sound. From what I can tell, the pick-ups are adjusted correctly.
Is it the way I play (read: bad), is it the guitar, is it my recording technique, or is it normal? I record direct into the Hi-Z of an Aardvark Q10 interface/soundcard using a 1984 Peavey T-40 with humbuckers, and monitor through Mackie HR824.
Thanks in advance for any ideas or suggestions
