O
oczad
I am glad it finally worked.
Next time, just read the instructions first.
Latest audio driver should be installed before you even connected your card.
Then, re start ....
Enjoy
Actually the reason i didn't read instructions is because i have installed and uninstalled this card probably 6-8 times before and always had it working fine. I only use it rarely, and when i do i always uninstall it after because i go for a year at least between uses and prefer not to have the last slot taken up or hardware installed i don't use. So i had no reason to expect i'd have probelms getting it to work when it always did in the past after installing it. The only thing i can figure is the new rig. Technology both in hardware and windows has changed some since this card came out, so maybe that has something to do with it.
