sync
Pending
I'm looking for a compressor/expander plugin that has threshold, ratio, gain, attack and release controls and nothing else. The ones I've seen have too many controls for me.
Their classic free compressor is the first one I've seen that is simple enough for me. But I want one that also does downward expansion.michaelst said:
masteringhouse said:You can't get much simpler than an LA-2A. Threshold and gain. That's it.
Yeah, 'less' or 'more' has got to be about as simple as it gets.mshilarious said:Well, the SSL LMC-1 technically has three knobs, but it LOOKS simpler![]()
sync said:Wow, so there are actually few compressor plugins that are simpler that what I'm looking for.
All "standard" compressors apply downward compression. If you're talking about DBX noise reduction techiques, then that's actually using upward compression followed by re-expansion.sync said:I'm looking for the software equivalent of one of the DBX compressors that also do downward compression.
The ratio control in a downward expander allows you to control how much noise you let through. A noise gate is a downward expander without a ratio control.Yareek said:Why don't you just use a noise gate and dial down the noise reduction?
Yep. Check out the "Dynam-izer" at Roger Nichols Digital.sync said:Does anyone produce a high quality Graphic Dynamics plugin?
I downloaded the manual and it looks very interesting. I think it might be a little complicated for someone like me who is just starting out using this stuff. Regardless of that, I don't see myself paying that much for one plugin right now.SouthSIDE Glen said:Yep. Check out the "Dynam-izer" at Roger Nichols Digital.
http://www.rogernicholsdigital.com/dynam-izer.htm
There's no other graphic compressor/expander like it, and it actually sounds quite neutral.
G.
sync said:The ratio control in a downward expander allows you to control how much noise you let through. A noise gate is a downward expander without a ratio control.
I once had a freind who, with his dad, ran a structural engineering firm. Really brilliant people...in a limited fashon.sync said:I downloaded the manual and it looks very interesting. I think it might be a little complicated for someone like me who is just starting out using this stuff. Regardless of that, I don't see myself paying that much for one plugin right now.
