can you mod a volume pedal to 10k?
  • Thread starter Thread starter sach16
sach16
Hi all,
I bought an Ernie Ball volume pedal (25k log. pot) to use as an expression pedal on my eventide eclipse which i've now found out needs a linear pot of between 5k and 20k.
On the ernie ball site it says pedal pots should not be modded - but manufacturers always say things like that! does anyone know if its possible /worth getting a tech to d, or is it definitely not gonna work?
Or can anyone recommend a decent robust 10k linear vol pedal with a good sweep range (more sweep than those roland ev5s)?
thanks for the help!
sache
sach16 said:
Hi all,
sache
You'll probably have better luck looking for something that is designed to be an expression pedal rather than a volume pedal. Vol pedals have log (audio) taper pots because our ears respond to volume in a nonlinear fashion. An expression pedal is designed to feed a linear resistance/voltage gradient to electronics, which is what you want, otherwise you'll have your parameters changing a lot for a little pedal sweep at one end of its travel and only a little for the same amout of pedal at the other end. Also, many volume pedals are buffered for an audio signal and won't know what to do with a DC control voltage.
hey, thanks for the reply - i get it now, i need an expression pedal... any ideas on a robust 10k pedal with a good sweep range?
