P
prayingd
This may sound stupid, but I’m on the level here. Please give a listen and provide any direction/input that might be helpful!
I have a new Fostex VF160 unit that is still unopened in the shipping box. I ordered it after 2 weeks of research into similar 8/16 track recorders. From what I read, the 160 provides the “most bang for the buck”.
But after doing more research into this unit, I’ve discovered the following. Many VF160 users, although stating that the learning curve for competitive units tends to be “steeper”, still admit that the VF160 in not exactly user friendly, especially if one has little recording experience and must rely on the manual. A few “experienced” veterans even admit to being baffled regarding certain capabilities of the machine, even after using the unit for over a year.
OK—I fall in the category of the technically challenged. I’ve only used a 4 track Tascam Porta-3 cassette recorder. And IT was a challenge at first! (I also have limited experience with a Tascam 488.)
Is the VF160 destined to sit on my desk with only about 10-20% of its capabilities ever realized? ($799 paperweight or frustration box?)
Here is the good news—my recording needs are SIMPLE! 98% of my work is pure vocal (acapella) gospel music. I stack my voice up to 8 times (maybe more with a 16 tracker), singing 3-5 part harmonies. I have a new MXL V69 Mogami microphone and a small pre-amp (no compressor…I read that the VF160 may have a usable one?).
So I need to know…what do you think my chances are of learning this machine well enough (in 2-3 weeks) to do some serious vocal recording and justify the cost?
Even more importantly, what do you recommend in terms of tips or DETAILED INSTRUCTIONS, as far as using it for my purposes?
With time, I know I can experiment much more with the sound, but how hard will it be to record my voice on 8-16 tracks, mix down and burn to CD (burner installed)?
Should I keep the VF160, or send it back (unopened) for a full refund, “back up” and go with a 8 track digital machine like the Tascam 788 or one of the “older” Fostex units?
THANKS for your input. It will HELP.
Dennis Swindle
Adrian, MI
Dennis Swindle
Adrian, MI
