Yes, the extra memory can help with samplers, looping applications, and so on...as I mentioned.
For general audio tracking, no, it will not help you.
Doc, the "headaches" I refer to are random lockups, explorer crashes, data corruption...the usual memory problems. A lot of motherboards spout off about supporting 1GB of memory, but that doesn't mean that the manufacturer anticipates people using large memory sizes! One of the most common things you'll see in a BIOS revision log is a reference to "fixing such and such with memory sizes > 512M", etc. Then of course Windows 9x has a few problems with large memory sizes, but they have workarounds (plenty of FAQ's on the net in this regard). With memory sizes over 512MB, it has historically been advised to use registered memory....without going into detail, let's just say that registered memory drives itself, while unregistered memory is driven by the board. Crucial.com has some good faq's regarding memory selection, and they get into some of the technical stuff without getting nerdy. Yes, mixing and matching a bunch of sticks is also a headache...if you go to 1GB the best configuration is probably 2 512MB sticks of the same make & model.
A RAM disk is kind of an interesting idea but.....man....can you imagine tracking several takes and then having your computer crash? I guess you could just load playback tracks into the RAM disk. The only problem with that idea is that a single 7200RPM drive is going to do you for at least 32 tracks on a well-working system.
Maybe we should ask "how many tracks is *more* tracks?"
Slackmaster 2000
