SFDave
Let me start by saying my setup is unusual, so bear with me. Instead of using studio microphones to record an acoustic grand piano, I'm using the Helpinstill stereo pickups (created for use in live concerts where acoustic pianos are on stage with electronic instruments and feedback is a problem, i.e. Billy Joel and Elton John both use this system). These are magnetic pickups and function the same way guitar pickups work. Unlike mics, the output is initially unamplified. As you would expect, the sound is very dry and needs processing to add ambience - reverb etc, all of which is done in LogicStudio. It's only been recently that this system has begun to be used for recording purposes, and I may be one of only a few people trying to go direct to digital with it. Though it's not really any different than recording an electric guitar directly to computer.
The controller box has both balanced studio type outputs (low impedance?), and optional regular unbalanced large phono outputs. I am using the large size phone plugs with adaptors to reduce the two mono lines to a single mini stereo plug which goes into the mic input of my Mac Powerbook running variously, GarageBand or Logic Studio, and I'm sure the computer input impedances don't match the pickup's output.
My problem is that the signal is apparently recorded OK, volume levels look OK - when I view the waveform in an editor, it shows up as a nice fat wave barely contained within the clipping barriers. However, playback has a very low volume as if the piano were in another room with the door closed. Using a waveform editor to "amplify" the soundwave only makes for some nasty clipping, and the volume isn't any better.
My question is, is this a problem with impedance mismatching? I'm aware that mismatched impedance can cause degradation of the higher frequencies and add distortion or noise, but the overall volume is my issue. Could using a simple pre-amp solve the problem, or would that just make the same problem worse by adding noise? Is it worth a couple hundred dollars to add something like the Radial Engineering JPC Stereo PC DI Box into the mix? Or would the Yamaha AUDIOGRAM6 which includes a pre-amp and, I think, performs impedance balancing as well be a good idea?
Sorry, I'm not a sound engineer, so I'm hoping someone will understand my problem and can help find the right solution before I spend a bunch of money on the wrong one. Thanks!
Dave
Dave
