V
Vigilante
Gear nut
Hey guys and gals, question:
I have a 600W 5disk DVD changer, a Panasonic SA-HT670. The unit "would" work, except for the drive trays screwed up, and the dude who had it, was just forcing the trays in and out until it just busted completely and none of the 5 trays work anymore. Let me put it this way, the WHOLE of the disc changing/playing assembly no longer works.
However, the unit itself still works fine, I can output the FM signal to my speaker and all seems normal. The problem is that the unit thinks there is something going on with tray 1. The Tray1 light is on, and the disc1 graphic in the display is blinking. And so the unit will only switch to FM/AM and back to CD. It will NOT change to any other inputs, which it has 3 inputs. It just won't do it.
So we took the whole drive assembly out and took the control boards off. We were messing around with pressing the various switches on these boards, but any of the switches pressed, or ALL pressed, doesn't change what the system thinks is going on.
Thus brings me to my question. I can't get the unit to switch to aux input because of what it thinks is going on with the DVD. Is there a way to FORCE it to use aux input? Or in other ways just "pull" the amp out of it and use it standalone? Is there a way to trick the unit?
Nothing we try makes it stop blinking the DVD and lighting the Disc1 light. Even disconnecting the two ribbons from the drive tray and pulling the whole thing physically out of the unit and disconnected, it STILL blinks the disk1 as though nothing even happened! The entire 5 disc changer/player unit is gone out and I still can't switch to aux input or any other input but FM.
This is bugging me, I'd like to use the 600w amp in this thing. ANY and all help and suggestions please don't hesitate to say your peace! Thanks.
