When the power diode tube was pulled, all power to the amp stopped. Even if it has a bridge rectifier, w/o any laod, theere will be no power generated to da any damage - the input is what causes the amp to <GO>, otherwise it is like a bike on a hill, waiting to roll down...As for the speakers, it is the resistive laod presented to the amp that determines what power comes out of it; that is, if 2- 8ohm speakers are connected in parallel, it will look like 4 ohms, If 2 - 4ohm spkrs are connected, it will look like 2 ohms. When the load resistance goes down, the pwoer goes up until the signal (sound) coming out of the amp is as large as the power supply voltage, and then it begins to distort. Less load = more power, limited by the internal pwoer supply. That is why, and I don't recomend this - Eddie Van Halen used to use a variac transformer to boost the 115VAC wall pwoer to 150, and get more sounds. I SAY AGAIN, I DONT' RECOMEND ANYONE DOING THAT ! HE HAD PLENTY OF MONEY TO BUY NEW STUFF WHEN HE SCREWED UP - DO YOU ? That is today's lesson amp electronics. I hope it helps !
Cape Chris
'70 Les, Gold Top
