Can i connect uca202 with behringer xenyx 802
  • Thread starter Thread starter Dado
D
Dado
Ok so im planing to buy a FCA222,Uca 202,UFO202 or UCA222 so they are preety much the same with some small differences(sorry about my english im a bit rusty:D). So my question was will i be able to connect it to a behringer xenyx 802 mixer and record with the mic pluged in to the mixer and how should i connect it? And is it a good option for recording rap vocals (i dont need crystal sound) ? Thanks in advance and im sorry again for my bad english.
Dado.
Whats up Dado!!!!!
As long as your 802 mixer has Tape Outs you will be good to go.
You would plug your mic into your mixer......you would then route the signal from your mic to your Tape outs.....
From there you will connect RCA cables from the tape outs......to the Inputs on the soundcard......in this case im talking about the Behringer UCA 202.
The UCA 202 will then convert the mic signal from Analog to Digital........After your signal has been converted to digital it is sent down the pipe........or USB chord which is hooked up to your computer.
Make sure you have your "soundcard......or interface........or the UCA 202.............these are all the same thing" as the selected device when recording to your sequencer program.
Check out this link..................http://www.tweakheadz.com/guide.htm ..........
its not specific to what you are asking but i can PROMISE you that after you have read tweaks guide......you will be VERY informed as to the basics of recording!!!!!!!!!!!
I wish the best of luck to ya!!!!!!!!
cheers
