M
Marci
Here's one for y'all...
I have set beside me a HP Surestore DAT8 C1529K
It's a SCSI 4/8Gb Dat Backup drive, but the question is this:
We all know that you don't need an analogue audio cable to listen to CD Music on a PC, as a fast PC can digitally extract down the data cable... what I want to know is is there any software that allow me to use the same principles with this DAT drive, in effect converting it to a stereo 4mm ADAT?? There's no reason why it shouldn't be possible as what gets written to tape (and in what format) is governed by software, not the drive. All the drive does is write what it's told to write... so if you could tell it to write audio then it would... but does anyone know of any software that'll let me!!! If anyone knows if it can be converted into a 4/8ch ADAT then that'd be even better...
PC Spec:
I-Will XP333-R Mobo, Athlon XP2000+ CPU
768Mb PC2700 DDR Ram
80Gb UATA133 7200rpm Maxtor HDD
24x10x40 CD-RW (4 of)
Hoontech DSP24 Soundcard with DSP2000 C-Port
OS: Windows XP Pro
Recording with: Cubase VST/32 5.1.1
Cheers!
PC Spec:
OS: Windows XP Pro
Cheers!
