B
beesee
I want to integrate a console with my Digi 002 rack. I have everything mapped out so far (patchbay, converters, I/O, ect). The one thing that remains is the monitor outputs on the 002 rack. Essentially, I want to use the jacks to feed the console's control room volume knob & forget about the volume knob on the front of the Digi rack. Maybe it's a long shot but, is there any way to bypass this? Or, should I try calibrating the 002 output volume to the console? If this would be the case, what would be the correct way of doing so? I'm guessing by using pink noise.....unsure from there on. My reasoning is that I want to tuck the 002 in the corner of the room, use it only for I/O, and forget about it. I want to run 18 out to the board for mixing/summing so, I would be using main outs 1&2 as channels. That leaves me with The 2 monitor outputs...... I want to be able to mix ITB as to not disturb the talent while recording so I need to be monitoring from PT monitor out 1&2. I suppose one possibility would be to leave the monitor level knob in one place, but what is the right place? All the way up? can anyone pick up what i'm puttin' down? Any thoughts would be greatly appreciated.
