Cakewalk Pro 8 Direct X
  • Thread starter Thread starter Mbest
M
Mbest
I am using Cakewalk Pro 8, and I can't figure out how to use Direct X effects plug ins.
Does this version of Cakewalk even support Direct X.
Thanks.
Sure it does
What can't you get it to do?
Do a simple test. Create an audio track. Next open up the console view so you see your tracks in a mixer kind of way. Next right mouse click on the black window just under the track name and your plugs should be sittin there for you to choose from.
Good luck.
8 supports direct x pu, long as they is loaded proper. Check your control panel to make sure.
