Cakewalk HS 2000 and FruityLoops
  • Thread starter Thread starter The Hat
T
The Hat
Looking for a drum machine software to add into the mix for Cakewalk home studio. I have FruityLoops 2.7 Express and it appears to be okay, but before I upgrade to the real version, wonder what others might think...
Does FruityLoops 3.5x work good with Cakewalk Home Studio or is there something else out there that is better ? in that relative price range.
What do you mean by working good?
HS2002 can make use of any ACIDized WAV Loop created by Fruity Loops. It can also work as a VST instrument. With the use of a VST to DXi wrapper, it can become another DXi softsynth like the ones that come with HS2002.
I use FL in Sonar/HS2002 as a VST/DXi synth as Brzillian described and consider it the best synth for creating drum loops within Sonar/Hs2002.
By works good... when I dropped a loop into CWHS 2002, it sounded a little muffled. I'm sure it was becuase I exported it as a wav file and then imported it into CW that way. I'm still learning.
There doesn't seem to be a lot of documentation on how to get the files into CW from FL. Any suggestions are welcome. sounds like I will upgade and learn...
Thanks
any documentation on this
<<With the use of a VST to DXi wrapper, it can become another DXi softsynth like the ones that come with HS2002.>>
Is there any go documentation on to do this? I trying to figure out the best way to get it in CW.
Thanks
I use the fxpansion wrapper:
www.fxpansion.com
A good forum is :
www.kvr-vst.com
I hope this helps....:)
BTW, an imported wave in Sonar/HS2002 should not sound muffled...unless it was recorded and/or saved muffled? What does it sound like in any of your other sound players i.e. Win Media Player, winamp, Real player etc.? It should sound similar.
