CakeWalk 2002 effects
  • Thread starter Thread starter LuvMacheen
L
LuvMacheen
Anyone ever use effects in 2002 to somehow make your 6 string sound like a 12 string?
It aint gonna happen. :(
Most pitch shifting effects only work on monophonic sources and can only change pitch one note or or so without sounding terrible.
If you want a twelve string sound,get a twelve string.
You can also try doubling the part. If it's chords you're playing, play the doubled part in a higher fret position.
There is also another trick which I have never tried myself, called Nashville tuning. Basically you restring the lower 4 strings of the guitar using the higher octave strings from a set of 12-strings. Play the part once strung regularly and then double it using Nashville tuning.
