P
psmurf
Hi all, I'm looking at old houses - townhouses, duplexes and some detached. These are all from around 1875ish and are almost all brick with plaster walls (and cellulite or no insulation ... I really have no idea what's inside the walls). I'm looking at the old stuff cause these places really inspire me ...
I want a space to practice loud guitars and drums, and knightfly had responded to some questions of mine a while back saying that it should be possible to build a small space in the basement of a modern townhouse that would allow for playing drums at night for a couple of thousand without getting any death threats from the neighbors. A big drawback with these old places is that they really don't have basements ... just cellars meant for the boilers and storage. Another drawback is that these places are typically 13-14 feet "wide", which potentially limits the dimensions of the room. Also I imagine that older, dried out wood is more sound conducting.
A plus is that most still have plaster instead of drywall, which should suck up low frequencies a lot better than drywall from what I've heard.
Some of these places have garages, but I'd rather not use the garage since they would be lacking heating/cooling.
The room I want to build would be maybe 11' by 13' or so, maybe a little longer and would probably be put on the second floor of the house. I have no idea how I would tie in the HVAC. Some of these places still use hot water radiators and have no central A/C ... so in that case I would probably remove the radiator in the room and use space heaters and fans. I understand I would need a floating floor and ceiling and probably staggered stud construction with multiple layers of drywall (I'll put together some pontential schematics after narrowing down the house search).
any thoughts suggested - both about the house and room
