Burning issues
  • Thread starter Thread starter tsliste
T
tsliste
Hello every time I try to record a block of songs from my itunes(sent from my garageband) After 1 or 2 songs a medium error occurrs. What can I do to prevent this from happening again??
Thanks!
Clean out the gunk from inside your burner. Try compressed air.
I would add something here, as I have a little knowledge on this subject, but the above posts pretty much cover it.
The most common reason that would happen to me?
The blank CDs themselves.
Good luck!
Thanks for all the responses. I have tried a couple different blank Cd's(Dynex and Nexxtech) and have not had luck with either. Are their some nicer blank Cd's available that I should use? I tried reducing my burning speed to 12x and I also used a cleaning cd on my Mac. I still can't get my computer to burn more than 3-4 songs at one time. These songs are being sent from my Garageband to my Itunes. I tried burning a regular cd(10 or more songs) and it worked. Any ideas for what I am doing wrong??
Wait... it only fails on tracks from GB? What sample rate/bit depth? Maybe it is trying to do on-the-fly conversion and isn't quite able to keep up.
Dumb Question:
How to I find out the sample rate/bit depth? I think the problem does have something to do with errors in the conversion.
Thanks!
GB is WAY out of my field of expertise, but, it seems from some stuff I have read online, that GB *may* only do 16bit/44.kHz, which is the right sample rate and bit depth for CDs. If thats correct, it could still be your machine not being able to "keep up" (which is to say that the machine is trying to burn, but has to do too much in the way of things other than the actual burning itself..i.e. conversion of file formats, etc.), then one thing that may help would be to convert the songs to "final" file format first to make that part of the process a separate thing from the burning, then later, to burn those files to a CD as an audio CD.
This page seems to have a method to do that, it refers to it as the "Never Fail" method. (dunno if it will help tho)
http://www.thegaragedoor.com/tutorials/faq.html
If you have the option, burn your CDs at the slowest speed possible. Also, don't have any other programs open when you get ready to burn the CD.
That said, "medium error" does sound like something in the actual burning, most likley, the discs themselves, because the "Medium" they refer to is the disc itself.
So, with that in mind, the following things may either be things you already know, or (hopefully) they will be helpful. It wont hurt anyway.
CDs are written to by the computer on the *opposite* side that you would write on if you were labeling them with a sharpie.
Especially before burning, don't let anything touch that side of the CD, and don't place that side down on anything. On CDRs with writing on them from the factory ("branded" CDRs, as they are called, will often have the company name on there, for instance), the side without the writing is far more delicate than the side with the writing (from the factory) on it, and any impurities on that side can potentially muck up the burning process. A smudge that would not cause a skip on a CD that was already burned when it got the smudge could easily cause the CD to error out while trying to burn it.
Ideally, you would want to take the blank out of the package and put it directly in the computer when it is ready to be burned.
If that doesn't help, one thing you can possibly do as a work around is burn the WAV files you make (with the advice from the FAQ page linked above) onto a CDR as data files, as versus burning them as an audio CD, then take that CDR of data files to another computer, and copy the data files onto the 2nd computer, and burn them onto a CDR as an audio CD on the 2nd computer. It sounds worse than it is, actually. The reason that might help you is that burning a data CD employs all kinds of error correction that burning as an audio CD does not employ. That error correction could be enough to get you past the CDR drive and/or CDR Media and/or computer issue you are having now on your computer.
That is pretty much all I have, so if all that fails, it may be that your burner is the issue, or that you just haven't found the right blank CDR brand yet.
Good luck. Let us know how it goes if ya can.
G
I would guess if your hardware is in good condition that it's probably an iTunes thing. I'm always a little wary about using iTunes to burn since when my band recorded an album and iTunes decided to insert 10-30 seconds of dead air after each track!
If you're on XP CDBurnerXP is a decent free tool. (The link may be wrong. It's been a few years since I last downloaded it...)
Thanks for all the responses.. I am going to try and figure this out based on your suggestions this weekend. I will let you know how it goes!
Thanks again!
