F
Fusioninspace
This is one of those frustrating projects I felt compelled to share.
I started putting together a baritone a couple of months ago. Most of the parts were from my MIM strat - but I got a Dano neck to go with it. By chance, my job and personal life got extremely busy about the same time - so I had to work on this thing in 10 minute segments over several weeks.
So the neck comes in, it turns out it's a tad wider than the neck pocket in the strat body. I figure the neck has more value than the strat body so I chiseled out strat - that parted turned out real nice.
Then I order a loaded pickup cover - It's nice, but p'up covers are white and I wanted black. So I ordered a black trim kit (covers, knobs, etc.). A few days later, I pull off the pickups and swap the bridge position cover - fits perfectly. On the middle and neck pickups the little holes in the new covers don't match the poles on the pickups
Ok, so I dremel out a slot on the covers and now they fit - It actually looks kinda cool. Now simply pop the pickguard on the body....
Um, the screw holes only line up for about half the screws and the Dano neck has a slightly different shape than the pickguard. Now I know that an 11 screw pickguard does not mean 11 screws will line up. Dremel time on the neck area and a few new holes later - that part looks great!
Ok, now simply solder the wires and I'm ready for the next step. Except when it's 11:30 at night and you're extremely tired and you don't realize you soldered the shielding to the tip connection on the jack. But I do eventually realize it down the road.
Ready for strings! - Sort of. Strings go on... The neck is way out of wack and needs adjustment. It's then that I realize (I have a lot of realizations on this project), the adjustment is not on the head of the neck - it's burried under the pickguard, behind some wood in the body. Ok, pickguard off, chisel out plenty of access to the hex bolt - adjust the neck relief, pickguard back on, presto!
And this is where I discover the jack in not wired correctly. Ok, next.
This is where the I must of had a breakdown of some sort. I start tuning the strings to B - similar to what I do on my 5 string bass. From there I do a setup - I still have the strat trem mind you. So over the next few nights, I do the bridge and intonation, etc. It's real funky, slappy, fretless sounding when I play it. And I play it for a few days and nights (again 10 minute segments or less). And it sounds just TOOOOOO weird to me and I don't know what's wrong. This is a project from hell with no end.
So last night I get on Youtube and look up baritone. I suddenly realize I had tuned it a full octive down from a normal bariton!!!!!
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHH
Shame on me.
Ok, time to tune it correctly - Trem starts to give way - added the last two springs, trem back in place. Tune away, now the neck is bowed hellishly.
So fellow enthusiust - I'm back to the pull the pickguard, Adjust neck, replace pickguard, reset string height and intonation...
Piece of cake! So I'm almost finished. And I actually think it will sound as good I wanted. Just took me a little more effort than I expected.
BTW, I had also bought two baby ducks about the same time the baritone project started - I had to take care of them and build them a backyard run after work during daylight hours. Ducks are done for now.
Shame on me.
