Building a pedal board (Question re: wiring, FX loop, delay, etc.)
  • Thread starter Thread starter Steve Henningsgard
Steve Henningsgard
Steve Henningsgard
I need a pedal board, I'm relatively handy with a soldiering iron, I've got a great understanding of signal-flow when explained properly, and I learn quickly. That said, do I have what it takes to make a non-shitty, rugged, relatively nifty pedal board?
Obviously, the easiest way to do it is to just duct-tape a couple of power strips to a plank of wood and call it even, but I'd really like to incorporate some semi-interesting signal chain stuff, especially with regards to delay. For instance, I'd like to be able to have my delay in the FX-loop (which, in my amp[JCM2000 DSL], is non-switchable.), and I'd like to be able to keep it on during the entirety of the performance, so I could play a distorted/delayed part, and be able to switch to clean during the part, but still have the tail of the distorted part feed back. (Hopefully I explained that reasonably well!). I'd also like to have the channel/reverb switches built-into the board, vs. having individual pedals for channel, reverb, and the aforementioned FX loop.
Is this stuff relatively simple? The biggest problem I can see is that, were I to use standard 1/4" cables, I'd have 5 of them going to and coming from the amp/pedal board, as well as a power cable, which would be a disaster/nightmare for obvious reasons. I'd need to make some sort of snake, hopefully that could also carry power (which, to my understanding, as long as it's already converted to DC, won't introduce any hum, correct?).
I'd like to build as much of this as possible myself, without having to resort to purchasing ready-made stuff. However, I know my limitations, and if something like a 9v distribution box is too complicated for someone like myself to build (I'd really like to make sure everything's getting clean power), advice as to which ready-made product might fit my project (and less-than-stellar budget) will be welcome :)
The cheapest, cleanest and easiest power for your board is this.
http://www.visualsound.net/1spot.htm
Works on up to 8 pedals at once is easy to route and hide the cable.
Here is my pedal board which is actually an inexpensive case with removable foam. Under the top layer resides the wires and one power strip which has the ac plug for the entire chain. This is built for the road.
The external footswitch bar allows complete bypass of any pedal and the entire signal chain runs from a 1/4 to XLR adapter which takes me from hi to low impedance (allowing long runs without signal loss) then at the other end I have the opposite plug which goes into the effects loop on my amp.
The cheapest, cleanest and easiest power for your board is this...
My old drummer has one that he's had at my house for months. I haven't talked to him since he quit, so... I'd say I have one! :)
Holy cool! So essentially, your pedals can all remain "on," and all you do with the external board is switch the routing to/from the pedal on or off, correct? That's a sweet idea :D I may have to directly rip it off! hah :p
Do you have a picture journal or anything like that for it?
Could you not achieve this with some sort of A/B pedal? I'm in the process of designing my - rather simplified - pedal board. I think it pays to think about it before you get the wood and nails out.
Essentially, that's what I'd want yeah. I'd need the signal from the delay pedal to the amp to be uninterrupted, allowing me to delay only signal notes or phrases, and also allowing me to switch from clean to distorted without changing the signal coming from the pedal: meaning, if I play a distorted solo with the delay on, I could switch to clean and still have the tail of the distorted section delay over a different clean part.
I'm explaining this as best I can: hopefully it's translating well :)
I get you alright, and it sounds cool. Honestly, I'm at a loss at how to go about it though!
I think your A/B selector is a good call. The routing looks like this to me:
Guitar > Tuner > Noise Reduction > Wah > Amp In
Amp FX Out > A/B Switch (A > Delay , B > thru) > Amp FX In
Plus the two cables for reverb & channel switching. I think the best option would be to build a box w/ three switches: for reverb, channel, and A/B. I'm drawing out a layout now, but it looks like I'll need to run 5 signals back and forth from the pedal board. What would I need/want to do in order to convert the signals to XLR? I'm assuming a 30' or so length of XLR snake would be my best bet for connecting everything?
Here is a link to the guy that makes the switching unit I have. It costs a little over $200. http://www.loop-master.com/
He makes them up to 9 pedals with a global bypass and separate tuner channel. Amazing product for the money. The only hassle is building your own snake to accommodate all your pedals. I just picked up a Hosa snake at GC, cut it in half and soldered the connectors. Took a couple of hours.
The whole thing is real convenient to transport and set up. The foam lined lid keeps my pedals in place while moving and keeps my knob settings intact.
Man, just get a Pedal Snake. It's one of the best things I've ever purchased. It's a bit expensive, but setup is so easy. I run my footswitch (MIDI), power (2 9V DC lines), amp input line, and two FX loop lines with one cable, no signal loss. The pigtail ends are interchangeable, so they can grow with your rig.
