K
KingstonRock
PC load letter?
crosstudio said:Kingston:
what difference does separate IDE cables for each HD make? are both HDs wired to the same pins? if so, how does the motherboard distinguish between the master and slave drive?
It can a pain in the ass to fit the cables right, because the hardrives can be far from the optical drives depending on your case, but each of the two IDE connecters are on their own channels. Each IDE channel can support two devices. But, only one device can be accessed at once on each channel. By putting the drives on seperate channels, you theoretically allow simultaneous access to both drives.
If you look in your device manager, you'll notice that there is both a primary and secondary IDE channel, as well as the controller for the two channels. Usually one connector is blue and one is black, i believe black represents the primary channel, though it could be the other way around, i don't think it makes much of a difference though.
Eric
I didn't even think about add in cards
