legionserial
I built my pc 4 or so years ago, and I have to admit I have completely lost touch since then. I haven't paid any attention to all the new fangled CPU's mobo's RAM etc.
Basically, the PC I have at the moment I feel is completely fine for everything I need to do, and I have yet to run into any limitations. The only problem is, is that it isn't dedicated to audio, and its about time I had one that was. I tinker a lot with gaming pc's, and don't like doing it with a buttload of music on my pc that I don't want to lose (yes I backup but thats beside the point)
However, I am an avid gamer. The 'gaming' video card I have (FX6800) is, i feel, too noisy for audio. I also have an FX5950ultra which I feel is much better for audio. It eats less CPU cycles, and is super quiet. Just can't run any new games on it
I had been using the FX5950 up until this weekend, as I wasn't playing games much at all, and concentrating mainly on recording.
Anyway, I digress...basically, all I need to buy is a CPU, a mobo, a case and some RAM. I have 2 soundcards, one for audio and one for games, and as mentioned, the same goes for video cards, and I have some spare fans and heatsinks.. So that's kinda the really expensive shit out of the way.
My current specs are...
CPU- AMD Athlon 3200+
Mobo- Asus A7N8XE
RAM- 1GB Kingston Hyper X
Sound- Delta 44(audio) and SBAudigyZSPlatinumPro (gaming)
Video- as above.
Now, I do feel that those specs are perfectly fine for audio, I can happily run around 50 tracks with no problems (its just me, and my drums are done in battery, so I only track one track at a time, but perhaps I need to look into what I might need in the future...ie, once a real drumkit is involved). However, I do find this pc gets little too hot running games with the 6800 (70 degrees under load then it crashes unless I take the side panel off), despite looking very pretty and running pretty fast. Even gets a bit hot with the lower spec games, regardless of me giving it a good old dust at the weekend.
So basically I need some advice on motherboards, CPU's, and RAM. I have to admit I don't have a sodding clue about what RAM type I should get. I'm also not sure whether the new pc should be for gaming or audio, as, like I say, the current specs seem fine for both. However, I feel I could justify paying out for a new audio PC more than a gaming PC. On the flipside, my current pc works fine for audio with very little increase in temperature.
So basically if anyone wants to chuck any opinions my way on any of this, (ie what pc for audio, what pc for gaming, combinations of new harware plus the hardware I already have etc) it would be much appreciated. I really don't want to spend an awful lot of money. Couple hundred quid maybe (bout 400dollars), give or take (bearing in mind I have a lot of bits for it already). Suggestions welcome.
Cheers
Mobo- Asus A7N8XE
Video- as above.
Cheers
