D
dawg711
Hello all,
im a complete newbie, but have been doing alot of research for putting together my studio. below ive compiled a list of what im planning on getting (basic pieces) along with a few questions, any responses will be greatly!! appreciated.
Mackie onyx 1640i
cubase 5
line 6 pod x3 studio
drumagog 5 platinum
ddrum pro triggers
synergy origin aw300 (with added hardware and firewire ports)
KRK Rokit RP6 G2 Active Monitors
along with a bunch of mics and cables amps etc
1) i want to trigger the drums, will plugging them straight into the mic pre's and then altering with drumagog be a technique that can achieve high quality results? also ive decided it probably to be best to mic the cymbals?? also can drumagog settings be used to trigger live recording in real time? so i could maybe call up some pre sets?
2) for guitar i would love to mic an amp up and record, but also record a completely dry signal at the same time and then choose a guitar sound for it when mixing and blend the two together and with the miced amp use that alone as playback for recording purposes too. possible??
3) for the computer i know it's of huge importance to ensure its powerful enough to run, will this be sufficient. what would you recommend for rpm and how could i increase my cpu so it’s capable of running alot?
4) when a band records i would want them all to play together, just to determine the timing, create a click track and focus on the drums. can i plug all guitars into mic pre's on the Mackie and choose an appropriate sound in my daw just for reference then record them each separately afterwards?
5) for vocals would i be better off getting a different mic pre as appose to the ones in the Mackie?
ive already taken into consideration the acoustics and layout of my studio, including soundproofing etc, im fortunate enough to have a detached house with no neighbours to annoy.
as i said before im a complete newbie, so apologies in advance for any (stupid questions) i want this to be a top quality studio which could rival top quality recordings.
any feedback would be great!!!!!
David
Mackie onyx 1640i
cubase 5
drumagog 5 platinum
ddrum pro triggers
David
