My question above still stands, would a gobo with a plywood backing, 2" of 705 on the plywood, then 2" of 703 on the 705 be better than plywood + 4" of 703? I thought the 705 might be better at absorbing some lower freq's,
It probably would, if placed where it does the most good....ie...the corners of the room. However, without testing this in a lab, theres really no way to GAURANTEE the performance. Its all opinion.
So, heres my opinion. Look at it this way. To really absorb low frequencies, the treatment must be placed where the low frequency modes terminate...ie. the corners of the room. It makes no sense to place bass traps in the mddle of the room...ie...gobos as bass traps, although they will provide some low frequency absorpton, but not modal(from my understanding of modal absorption) I beleve you can verify this here:
http://forum.studiotips.com/viewforum.php?f=8
Hence, my suggestion is just use 2" or 4" 703 and be done with it.
The point of gobos is:
1. Placing a boundary between instruments to prevent bleedthrough. This means a boundary wide enough(2-4' is good) and high enough(6-7') to prevent high frequency flanking around and over. Two or three units around a vocalist or drummer should suffice depending on the micing situation. These will not prevent low frequency flanking, however they can attenuate them.
2. To prevent reflection back into the mic. The deeper the pile, the better it will absorb low mid frequency reflection. You can also make them diffusive on one face instead of specular, via well(QRD) type construction.
There are lots of ways to configure gobos, and even make the stackable. You can even make a gobo with one side with absorption, and the opposite side diffusive, and even alternate them
Like this....
You can make them half this height and stack them as well. Wheels help as well, but need an offset bracket to allow the gobo to come close to the floor.
Also, you can make both sides absorbant, but place spaced slats over the fiberglass on one face, such as John Sayers design
The middle panel should be fairly massive, such as 3/4"MDF or a layer of plywood and gypsum bd(drywall) or even cement board over a layer of another substrate such as 1/2" mdf. It all depends on availabilty of materials, you skill set, tools, budget, etc. There are many ways to do it. But the end result should be aimed at placing a sizable mass between instruments.
fitZ
