Budget floor tom mic
  • Thread starter Thread starter mikgag
M
mikgag
Guest
Which of these these do you think would do the better job at recording 2 floor toms (14" + 16") ...placing the mic in the middle of the two.
AKG D550
AKG D22
Audix F12
CAD KM212
plain old SM57
please don't suggest something like the md421 or d112, we're talking small budget here.
I only quickly compared these two, but it looks like the audix F2 has slightly more response in the low end than the CAD... the SM57 would be my very last choice.
So the CAD and SM57 are out then...they were my last choices anyway.
AKG D550
AKG D22
Audix F12
CAD KM212
plain old SM57
I'm using the F12 as my kick right now, with a RS 33-3032 on the floor tom. I'd like to upgrade to the...F14, i think it is...the Fusion dedicated kick mic. Then it would be a tossup between the F12 and the 33-3032 on the floor tom.
Pfft! The SM57 would be my first choice out of that batch!
It's the most widely used tom/snare mic in history! How could you possibly make it your last choice?:confused:
Record much?
Record much?
Couldn't agree more...it'd be my first choice hands down.
Frank
Record much?
Thanks. Very insightful.
I use 57's on the rack toms, but figured it wouldn't be the the best choice for the floor tom. If your infinite wisdom says otherwise, I'll give it a try.
Record much?
Yeah, only 100's of studio sessions and 1000's of live shows in the past 25 years. :D
Whatever. A late night/early morning response, let me add a little: If I were on a budget, I wouldn't be looking at a 57... Although I might go for the ES57 cloned version at a 3:1 ratio. And frankly the fact that the 57 is IS used so much, and is so overpriced, makes me loathe to use it or recommend it.
By the same token, the Ford Escort sold more units than almost any other car for most of its reign.
:D
My gut says that the SM57 is used so broadly not because it is necessarily the best for the job, but because it is the most common. Any number of dynamics should be fine on floor tom, and the SM57 lies somewhere in that continuum.
Yeah you know that most of the big PA guys like the 57 because its so common.
On another note...The PG52 is a surprisingly good low tom mic even if it is one of those 'budget' Shures.
I've heard an MXL 990 on floor tom and sounded surprisingly good. Check it out.
If you want a little extra "thump" out of the floor tom, you might also check out the Audio-Technica PRO-25. I saw these on closeout at MF last week for $50. I've used them on kick drums before with very good results.
I actually thought of those, but they're hypercardioid, and I'm sticking it in the middle of the 2 floor toms, so I'm assuming it wouldn't be very effective.
I use a CAD E-100 between my 14 and 16 inch floor toms and it sounds wonderful.
Actually I use them on all my toms.
It is not a dynamic, but it does have extended headroom and does not overload easy.
Used you can find them under $100.
I believe I was one of the first guys here (probably THE first) to ever try out and recommend the ES-57. They work fine on toms.
Here's an old sample from when I first tried them out.
(Yes, the playing isn't all good. Its just the sounds I was going for at the time)
:D
Yeah, because professional engineers in the record industry don't really care what sounds good on something, they just grab whatever's handy.:rolleyes:
PA guys like it because its response curve is tailored for feedback rejection---precisely the opposite of what I look for in a mic for recording, generally speaking.
It's a workhorse mic---acceptable on most things, ideal for few to none---and so most folks keep several of them in their studios for when they need an extra mic for something or for when other mics just aren't working for them for whatever reason. When you need to find five or six matching mics to throw onto a kit, odds are the only thing lying around in that quantity are such workhorse mics, so the 57s come out.
Also, they're nearly indestructible, which makes them a good choice for use near fast-moving sticks.
This post would carry so much more weight if you'd post that picture of yourself in front of that shelf with all your grammy's.;)
I just necro'ed this thread to say - wow there are some sandy vaginas up in here..
I've been using an F12. Works just fine.. 4 years later. Hi.
