G
Grandflash13
Hey all,
I am running into a bit of an echo problem in the studio for the TV station I work at. We recently did a set change where we basically just slid the desk back a few feet and did some relighting. In doing so, we have basically turned the set into a little bandshell and without as many lights absorbing the sound and with them being a bit further away as well we now have a little bit of an echo problem. The studio is about 20 feet or so high and what I am thinking we can do is get some heavy drapes and hang them in a sort of grid pattern up in the ceiling to help deaden the sound. Would this really help much or would I be better off getting some fiberglass insulation and make baffles out of them and hang them instead?
I do not have very many places I can treat because it obviously can't be seen on air so the ceiling seems like the best bet. I don't think building clouds would do much because they would be up so high since the lights are in the way. Also, I can tell you right now my budget for this will be very minimal.
If any of you have run into a problem like this before or if you have any good ideas I would sure appreciate hearing from you.
Thanks
Thanks
