Bouncing only one track!?
  • Thread starter Thread starter Radioheadkid09
R
Radioheadkid09
I have encountered an issue bouncing a Protools session where it will only bounce one particular track (the bass guitar track). Nothing is soloed or muted or anything and the master fader is level too. During the bouncing process I am able to hear all the tracks perfectly, however when I playback the audio file (.WAV) i only hear one of the tracks.
I have tried changing all the bouncing settings with different file formats and everything. Also, I copied all the unmixed tracks to another session and they work fine but the mix settings are not there.
I've spend many hours working on this issue and have come up with no solution. If anyone has anything to offer that would be greatly appreciated.
Im running Protools 9 with a Mbox2 through a macbook pro if that is of any assistance.
-Sean
Probably something to do with how things are assigned to the master bus and/or how your I/O is set up.
When you hit bounce there is an option that says "main out 1+2" or "bus 1" or whatever.
It's something that's almost always overlooked. check that it's set to your master output.
Steenamaroo you nailed it! Thank you both for your help and consideration!
-Sean
Good job, Steeny.
Also, an FYI for future reference:
If you have "mix settings", as you put it, that you want to move over to another session, open the session you want the settings moved to and go to:
File > Import session data...
Pretty nifty feature.
