M
Moniker
Hello,
I'm extremely new with home recording. I have an M-Audio Delta 44 and Omni I/O box. Nothing fancy. 2 channels, etc.
I currently got an internship at a fabulous studio in Michigan called Tempermill Studios (http://tempermill.com) and my boss gave me an old mixer that he doesn't use to take home and fool around with. THe mixer has 6 mic pres, and and 16 direct line inputs. it also has 8 Direct Outs, 4 Aux Returns and 6 Aux/Monitor outputs.
here's my question:
He just taught me about bussing in Pro Tools. This is a 4 bus mixer, and he told me to go home and try to figure out to bus tracks over to another on the mixer. I really cannot figure out. What I'd essentially like to do is have a like 2 tracks bus over to Bus 1 and use it basically as an effects send just to get the feel of this thing.
What I currently have going is this:
Mic into Mic Pre 1, I have a direct out in channel 1 going to my Presonus Tube Pre preamp, and that runs back into the Aux Return channel 1 (mono). When I monitor through headphones on the mixer, everything works fine. Now what I want to do is have this run directly to the left input on my Delta. After I get that working, I want to do the same thing with another channel into the right channel on the Delta.
The problem:
I cannot find where in the hell to run the out from the mixer to my i/o. The only place it works is from the Monitor output, which is not what I want to do. Am I doing this correctly? If not, can you help me understand the insanity that is bussing?
here's my question:
The problem:
