boss dr-880 seperate outs
  • Thread starter Thread starter resination808
R
resination808
OK, I have an 880 and I'm having trouble figuring out how to send my snare and my kick to the auxillary channels. If anyone has any ideas, let me know.
i have a 660 so i dont know if it works the same with the 880 but.....
1-press reverb or chourus
2-use the left and right arrows and select"ind1" or "ind2"
3-press "pad"
4-hit the pad to which the sound to be output through the indvidual output is to be assigned
5-use the tempo data wheel and select "indiv"
the verb and chorus keys are the indiv keys.
you can also select the volume level of the verb or chorus. this vol level will effect the inv output level.
when i was first trying to figure this out it was confusing. the manual was written poorly.
with the verb and chorus buttons you have individual levels for each button and than one for "all" turn the "all"to zero or you will get other pads audio coming out of the indiv jack as well as the kick or snare..
also you may come to a point where you are getting both kick and snare through one indiv output jack....this has to do with the "verb" and chorus" buttons and their vol setings.
you will have to play with it to get it to work. if you cant figure it out pm me and ill help.
-jay
