lo.fi.love
Functionally obsessed.
Oops.
I didn't realize that I had been overloading the preamp on a channel for TWENTY MINUTES.
My overhead lamp dimmed and my power conditioner clicked into "sag" mode. I checked the "OL" LED on the channel and it was glaring at me with its beady red eye. My mix did some weird things, and then the line went out. My overhead lamp went from brown back to yellow, and everything went back to normal, save the dead tape input on channel 2.
Lesson learned: Don't get so focused on your mix that you forget to check on your equipment. Ha ha ha.
OK, so my hunch is that I should be able to fix this. Pull the channel card and look for any visibly burnt / damaged components, right? Use the multimeter to check for continuity in several points of the preamp / tape in circuit. Compare against the schematic, and order replacement components.
Does anyone have experience with this sort of thing? I figure I'll have to do some hunting, but I think it's possible to fix this on my own. Thoughts?
