pipelineaudio
Changing nothing but the drivers from 3.6.7 to 3.6.8 I see this in the reported latency:
3.6.7
3.6.8
Now, before making any conclusions, I decided I better try the CEntrance Latency Test Utility, in case this was just reported latency and actual latency had not changed.
For some reason trying to run LTU on the 3.6.8 drivers results in an error loop. Thinking this was just the 8pre on one of my test systems I switched to another computer running an 896
Running the 3.6.8 drivers onto the 896, I was no longer able to select the adat I/O! At this point I called tech support. The said they never heard of either issue, and that there was noone above I could speak to.
In order to solicit more help, I posted this forum link: http://www.cockos.com/forum/showthread.php?t=19905
Jim Roseberry and some of the ADK guys frequent that forum, so a lot of times these are issues they have dealt with before. A REAPER user found a way to rename one of the motu files and get the LTU to run in 3.6.8 with these results
(3.6.8 dropped the 32 sample size so I'll start from 64)
Centrance LTU tests for 3.6.7.4:
64 samples buffer size:
Measurement results: 234 samples / 5.31 ms
128 samples:
Measurement results: 362 samples / 8.21 ms
256 samples:
Measurement results: 618 samples / 14.01 ms
Centrance LTU results for driver 3.6.8
64 samples
128 samples
256 samples
Measurement results: 1130 samples / 25.62 ms
Obviously, this isnt just a reported latency difference, its actual
For the tech support staff to NOT know latency had doubled? Please....
I then started a techlink to deal with this
MTL 19128 — 3.6.8.1 drivers functioning in an odd way
https://www.motu.com/techsupport/tracker/view_ticket.html?issue_id=19128
Thinking that I would reccomend to our users to run the earlier drivers, I was shocked to see that they were not available on MOTU's website! I pointed this out to MOTU tech support but as of yet have not seen a repost, but it gets worse:
You cannot just uninstall the new drivers and reinstall the old ones. If you do you get an error: "the driver is too old for your MOTU hardware"
Calling MOTU tech support yet again, I was told by the staff to "delete motu entries from the registry" then reinstall
For one thing, there is NO WAY I'm telling potentially computer un-savvy clients or even knowledgeable ones to go trolloping through the registry.
For another thing, since I have a backup image and was able to try it, that doesn't even work. Same error.
A helpful user at the cockos forum showed a way to get back the old drivers and it seems to be working, but there is NO WAY I'm going to reccomend a risky procedure to customers just to get around MOTU not making an uninstaller that actually works.
Now, this was more than a week ago, which is an eternity in REAPER time, but maybe par for the course in the new MOTU (as compared to the motu of last year who really had seemed to shake off the poor tech support they had back in the day)
If I call I mostly get a busy signal or I get another tech who says they have never heard of these issues.
I have an EXTREMELY hard time believing that anyone calling themselves "tech support" wouldn't know that the new drivers DOUBLE the round trip latency!
If anyone knows a direct line or email to a higher up, or can forward this on to someone at MOTU that has a clue, please let me know.
The 8pre is a SCREAMING value right now, and I want to reccomend it as highly as it deserves, but at the moment I simply cannot due to these driver issues.
Please help
3.6.7
3.6.8
128 samples:
256 samples:
64 samples
128 samples
256 samples
Please help
