Solved best way to cut customizable foam?
  • Thread starter Thread starter EpiSGpl8r
E
EpiSGpl8r
Guest
I bought an aluminum box with foam that came with it. The foam was in easy pull cubic squares. of course i didn't want them all the way out so i cut them in half, i used a utility knife blade. do you guys know how to do this so it works and looks better?
You can use a hot wire to cut foam, but beware - it does give off noxious fumes.
Many years ago I used to work at a place where they also made industrial models (you know, oil refineries, rail-car dumpers that sort of thing). One of the guys used a hotwire to cut foam for geographic contours. I think the wire was powered by a 12v car battery but I'm not real sure, it was a very long time ago (20+ years).
The hot wire gives a very clean edge and has the bonus of cutting square to the top & bottom faces if the wire is set up to do that.
Personally I'd prefer a very sharp knife and a LOT of patience.
BluesMeister
Put the foam in the freezer overnight. It will firm up so you can cut it better.
