Best way to connect M300 to Omni
  • Thread starter Thread starter wrenhunter
W
wrenhunter
Hi
I have a Delta 66/Omni that I am using with an XP machine. I also have an RNC that is connected via 2 insert cables to Insert 1 & 2 jacks on the Omni. I am using demos (for now) of Cubase SX and Sonar.
I am planning to buy a TC M300 effects processor, and would like to buy cables for it at the same time. I will use it while tracking voice, guitar, and amps via mic, and guitar/bass/keyboard direct. I might use it during mixing also.
I have been reading the M300 manual, and have an idea of some possibilities, but I am confused.
For example, one option suggested in the M300 manual (p. 14) is to use an S/PDIF connection. This would seem to work swell with the Delta 66 card, which has S/PDIF in and out. And I am not planning to use the S/PDIF jacks on the Delta card for anything else.
The other main option seems to be the "Paralell Setup" on p. 13 of the M300 manual: a TRS cable from the Omni FX Send jack (mono) to Left input on the M300, then two TRS cables to connect the M300 Left and Right outs to the Left and Right Effects Return jacks on the Omni.
What do you guys make of these two options? Or are there others that I have overlooked?
Thanks,
wren
