Best way to clean dirty knobs
  • Thread starter Thread starter fgonza2
F
fgonza2
Hi all, i am in the process of cleaning up that Soundcraft 32 that i got. Well...it is very dirty and it has 361 knobs/faders. Any recommendations to clean that, like putting them in some water/soap solution for a day or two or alcohol ? i'm sure someone has done this in the past. But rubbing them one by one will take some time... ideas welcome.
thanks,
Felipe
Warm soapy water and a toothbrush is how I do it. Some out them in the dishwasher but the results haven't met my satisfaction, so it's one at a time with the soapy toothbrush for me.
Or you could maybe try and ultrasonic cleaner. I heard you can get them fairly cheap. Just dump a bunch of the knobs in it with some
cleaning solution and let it do its work for a few hours.
I use this method too and generally let the knobs soak for a good 30 minutes first to loosen up the gunk, which is generally dead skin, natural palm oils, food particles and cigarette smoke! Yummy! :laughings:
Cheers! :)
One should not put their knob in anything/anyone that would dirty it in the first place!:laughings:
will try the soaking/toothbrush approach first and see how that goes. thanks everyone
And I also had success reversing yellowed plastic by soaking the affected parts in oxiclean for several days.
That's a good one! I've not heard that. I've only used the warm soapy water process, But...my wife is a dental assistant, and they have a ultrasonic...:rolleyes:
ok, after cleaning 680 knobs and removing 608 bolts to clean the frame i was about to shoot myself. These knobs are covered in rubber, so the ultrasonic and soaking in soapy water didn't work, had to use a brush on each. Here's a video:
SoundCraft Ghost 32 + Studer A807 - YouTube
