T
tonejunkee
How should I breathe? I want a deeper, fuller breath...............
Should I upgrade my lungs?
Will a $500 pen cure wrighters block?
Will a Neumann U470864 make me not suck as bad?
It will make you sound twice as bad as you sound now
Your motivation sucks and you cant even finish ONE FUCKING SONG without hallucinating about pro gear and drueling over the false promise of stardom. NOTE TO SELF - music is invisible and non-material - Sgt Pepper was recorded on an old-ass 4-trak. Gear will not improve your music, but knowledge will - I bet that 90% of you(us) are not using your gear to the fullest. YOU'VE GOT TO WORK HARDER THAN YOU EVER HAVE BEFORE if you are going to engineer AND perform. Dont get caught in the web of going back and forth either, IT WILL NOT WORK. The mentality of performing is light years away from the mentality of engineering. Get your settings down BEFORE you perform. BE SOBER while doing this, dont settle for an OK sound............tweak that shit until you IMPRESS YOURSELF. Spend as much time as you see fit to get the best levels/sweet spots/sound THEN when its all good, walk away...forget about it. Then when inspiration stikes, hit it hard like a storm...LET IT ALL OUT. I like the idea of improvising a whole album(shrooms may help for this) this is a great way of letting the ideas flow without trying to judge them.
later
later
