T
travelin travis
what would you consider to be the "current best bang for the buck" cpu, mobo, ram combo for daw use? overclocking included.
Well, first of all I run external reverbs.TravisinFlorida said:hard pressed to use a small percentage of your cpu? i definately want to know what you're running.
regebro said:Well, first of all I run external reverbs.Second of all I run a AMD Athlon 2400+, some bog standard ASUS motherboard, don't remember what graphics card I have, a measly 512 MB of memory (I need more) and an M-Audio 1010LT soundcard.
Some 5-7 tracks of audio, with maybe a compressor or two, and maybe 4 tracks of MIDI typically ticks well below 10% CPU load.
Reverb takes more processor power of course. And so does soft-synths, but those you can render to audio tracks to save processing power if you need to.
I'm sure that you can improve performance in various ways, and there are other threads for that, but for !/$ any standard lower midrange cheap system it most likly the way to go. Performance improvements are expensive.
