V
vicevursa
If you happen to own one of these check out this excel spreadsheet. Chart . If you use it this chart is for the echo and delay settings. I got tired of having to stop and do the math to figure out what the milliseconds my delays were set at using the the numbers 0 - 63. I do believe behringer has since started using real life numbers so you know exactly what you are doing on their new models of the virtualizer. This chart is based on what variation you are using. All you have to do is plug in the number you would use and it will tell you what milliseconds you are using. It also has a bpm chart that is quite handy. I asked a friend of mine to make this up for me. I'm a little lazy. Anyway, check it out...
Vice
Vice
