Behringer ECM8000 disassembly?
  • Thread starter Thread starter gusfinley
G
gusfinley
My Behringer ECM8000 had a problem so I opened it up. The first time I tried to pull the guts out it required a lot of force, so I gave up, because I needed to use it.
I opened it up tonight with force and ended up breaking the wires that lead from the capsule to the pcb board. Yikes!!
How does one get the capsule off of the mic so I can reconnect the wires?
Thanks for your help!
The capsule is threaded on with an adhesive, heat it a little bit, and you should be able to turn it.
