.... I figured it would maybe help out with the final mix if the DBX is engaged...
I guess on the same note, I'll ask what's a good compressor for direct recorded bass guitar? I am starting to use the DBX now because I'm having major track bleed issues when it's off, and I know the DBX does compress in a way but should I try anything else in addition?
Maybe in some live mix application it might be handy for a PA...???
Clearly some mixed reviews here but I guess I'll find out if it does me any good.
It's the audio equivalent of spinners (those wheel covers that keep spinning when the car stops).
I've had the 422 since it came out and wouldn't mix without it on narrow tracks, especially with dbx. I've never been one for "magic black boxes," but the hardware sonic maximizer is as close to one as I've ever used and actually did what it claimed to do. The sonic maximizer plugin is gimmicky and not helpful in the digital world and probably more harmful if anything.
In the analog world, accentuating high frequencies without adding noise was always a concern The hardware BBE units from that era worked very well for recording. I don't have any use for the units in live situations.
Narrow track/low speed tape recording struggles with high frequencies and dbx increases head bumb frequencies, so the BBE solution fits nicely in most cases.
I use an old Dbx 163x on my bass tracks sometimes.It's a fairly simple comp with a single slider to adjust compression and a gain knob.I find it adds some good punch to the bass when inserted after recording.
