Awww Crap!! Pro Tools Just Crashed!!
  • Thread starter Thread starter DonGraham
D
DonGraham
I have pro-tools LE6.9 on my mac g5....has been solid as a rock for 6 months!!!!...now.......IT says: "original disk allocation for this session can not be used. One or more drives can not be found or are invalid for this session. As a result disk allocation has been modified. Would you like to verify the new disk allocation?..............then------blank # of audio files are on volumes unsuitable for playback...would you like to copy them? WTF...it wont let me do anything!!!!! HELP!!!!! :confused: :confused:
make sure it's not something funky like you accidently have one of your session folder privilagies set to no access or whatever.
hi-lite the folder that the audio is in
file menu-get info
set permissions to read and write
under details select "apply to enclosed items"
check all folder associated with the session.
this may not be the problem, but it's the only thing i can think of.
good luck.
should have bought a mac...Oh you did J/K
I can't help you, hope you didin't loose anything big or you backed up, but I'll be getting m-powered in a couple weeks, I've got sonar now, but for $199.00 what the heck, at least I can say I've got pro tools;)
Have you done an OS upgrade? Pro Tools (and other Avid products) are notorious for having problems dealing with OS version updates.... Beyond that, no idea. Are you up to the latest version of 6.9.x?
Open up your Workspace Browser and set the drives back to "R" for record.
There should be R's under the A and V columns in the Workspace. If they aren't R's change 'em. Just click on them and they'll give you a list to chose from.
You can find the Workspace in the 'Window" menu.
If that doesn't work, go here and do what it says:
http://duc.digidesign.com/showflat....page=0&view=collapsed&sb=5&o=7&fpart=1#313423
For those of you s******ing about the crashed mac.... :rolleyes:... A simple setting reset, most likely caused by an OS update or program install, has set the drives to a different category in Pro Tools. Most likely nothing has crashed and nothing is lost. This has happened to me twice and caused about 2 minutes of down time.
Good luck.
Chris
WOW!!!! That's the first time I've ever had a post automatically censored!!! :D
s-n-i-g-g-e-r-i-n-g
Can you believe that? I had no idea that would happen!!
-Chris
Chris Shaeffer said:
s-n-i-g-g-e-r-i-n-g
-Chris
hahahaha...you used part of the word "******"
my morale of the day is - don't buy a mac....
but then again - I do REALLY hate the bloody things.
i have a mate who has the skill of making things crash, his first time ever using pro tools le and on a mac he got it to crash a couple times, he can make it routinely crash too lol its really funny
Good luck.
Chris
THANK YOU CHRIS........I did what you said and it worked!!!!! EVERYTHING is back.....easy fix.............BTW the mac didn't crash.....pro-tools just decided to turn itself off........after daily recording for 6-months this is the only problem I have ever had...often times running up to 32 tracks with automation and pluggins.......Anyway THANKS AGAIN CHRIS!!!!
I think I know your friend!! He works at the place where I'm the IT guy, right? ;)
Don: Glad it worked for you!
-Chris
