Schwarzenyaeger
Formerly "Dog-In-Door"
I'm automating something.
I set the markers with the grabber tool as always, then I hit F6 and try to pull down the region between those two points but Pro Tools instead moves the entire automation line up or down.
It should only be doing this if I'm grabbing the automation line behind the very last dot.
Why, man, why?
https://i.imgur.com/cJYsOUz.png <-- you can see how it's lifting the whole line instead of just the selection between the dots. It worked perfectly fine for the section just before that (and for the past 12 months, for that matter)
Also, why does the "Insertion follows Playback" function seemingly randomly turn itself on?
Why, man, why?
