stoobie
I'm using the Timeworks EQ that comes with Sonar 2 XL. My question has to do with EQ presets. The presets for the EQ (and any other EQ I've seen) work by adjusting specific frequencies by a set amount of dBs, regardless of the actual frequency response curve.
That means that (for example) if I record two vocal tracks, using two different mics (or using the same mic placed slightly differently), but want both vocals to sit in essentially the same "vocal" place in the mix, I can't use the same preset.
What I want is a tool that first analyzes the frquency spectrum and then adjusts the EQ settings to match a predefined target spectrum. That way, it doesn't matter what the source spectrum is. I can quickly set any source spectrum to an ideal target.
Does anyone know if such a tool exists? Does anyone use such a tool (or am I the only one that would use such a tool?)
stoobie
stoobie
