Michael Jones
When working a mix, it would seem that you have to establish a "point of view" for the listener; an Aural Perspective if you will. You have to decide where you want the listener seated, and adjust pans and levels accordingly. Right?
So, my point is: The bulk of what I write tends to be orchestral in nature, and is usually prepared for independent films. I try to take on the perspective of the conductor, and plan for my mixes accordingly, which envolves some knowledge of how an orchestra is laid out and seated. I.E. string section on the left front, horns to the rear, percussion to the right rear, so forth and so on...
Most of my mixes are done in 5.1 Surround Sound as well, so you can begin to see the complex "pallette" one has to work with.
Well, I had finished one of these sweeping orchestrations, and I was pretty happy with it, but wanted to get a second opinion on it, so I had a friend of mine (who writes in a completely different genre; more pop oriented), listen to it. One of the first things he wanted to do was to pan the strings center.
So, I'm wondering if this type of aural perspective, which I think adds a certian amount of authenticity to the mix, is lost on the lay-listener?
Any thoughts?
Any thoughts?
