J JPA New member May 6, 2005 #1 How do you record with an effect on input? Say I want to track an acoustic guitar with software compressor . Can it be done or only thru editing afterwards? Thanks
C CavityCr33p New member May 6, 2005 #2 And be heard at the same time? Yes. Audition doest not support ASIO, which is required for realtime effects monitoring.
J JPA New member May 6, 2005 #3 Would you be willing to sort of walk me thru it here? Much appreciated.
O ozpeter New member May 7, 2005 #4 I think Cavity was giving the right answer but it came out a bit wrong. You cannot record with effects in Audition. You can only add them after. If you spend a little time with Synthedit you may find you can design your own system whilch would enable you to do it (for free).
