J
jobones
Would there be a point to buying and installing 2 of these in the same machine?
jobones said:Would there be a point to buying and installing 2 of these in the same machine?
Not if you're adding on to an existing setup. D44 = US$200, AP2496 = US$150. Adding another AudioPhile is cheaper unless you can get a good price for your used AudioPhile. Also, the AudioPhile is a good choice if you need the SPDIF and/or MIDI functionality.brzilian said:Why not just buy the Delta 44 then?
I[t] would be cheaper...
Sklathill said:Actually, two Audiophiles in a Shuttle SS40 (mini computer with two PCI slots) for use as a standalone Gigastudio computer might not be too bad.
That's what the AP control panel's "multiple card sync" option is for. (It's on the Hardware Settings tab.)brzilian said:Only if you're absolutely certain that their internal clocks can be synced together. ...
